I’m trying to unblock a plugin (calc.rhp). I see that Pascal points to the general tab of the plug-ins properties dialogue. Unfortunately mine is not showing blocked (see attached). It does however show
the following message if I try to use calc.rhp: “Blocking plug-in Calc.”
Is it now controlled from within Rhino in version 6?
Thank you John, I went there first. If you look at my attached screenshot it doesnt show an “unblock” button. I checked each of the other commands in the property window just to see if maybe it moved. I also checked my webroot and malwarebytes. Nothing was blocked or quarantined.
Right, I should have asked, is it being blocked by Windows or by Rhino? If you crashed, previously,while running it, or Rhino crashed on startup while loading it (seems unlikely) that would prompt Rhino to offer to block it. My guess of the moment is it was a guess by Rhino as to what caused a previous crash.
