Unable to run grasshopper from rhino.compute locally
I am trying to learn rhino.compute and following the tutorial
I have been able to run the rhino.compute locally using visual studio. However when I run any example using grasshoper i keep getting the error below
However rhino examples are working fine.
I have tried the same by running the server from hops. And also on a different system.
I keep getting the same error. I am new to development and would appreciate any help.
Thanks
I also have a similar problem, which has not been solved at present. It seems that there is a problem with the gh file
Hi ! Did you try to work with python 3.12 and not above ?
