Rhino 7 compute Grasshopper
When a Python client sends a request to the Windows server an error occurs on the server. If the script is simple and without plug-ins, no errors occur. In the original project the script is much larger, so I tried to keep it as simple as possible, as I think the problem is with the plugins.
question.ghx (87.6 KB)
Errors:
[08:15:26 ERR] An exception occurred while processing request
System.NullReferenceException: Ссылка на объект не указывает на экземпляр объекта.
в Heron.SetEAP.SolveInstance(IGH_DataAccess DA)
в Grasshopper.Kernel.GH_Component.Solution_Compute_MixedAccess(GH_StructureIterator it)
[08:15:26 ERR] Solution exception:Ссылка на объект не указывает на экземпляр объекта.: component “SetEAP” (7431c12d-4774-45ba-a92f-929934300662)
[08:15:26 DBG] Tree contains more branches than this component has output parameters.: component “BANG!” (048f7130-e2f6-4324-8acf-9a1dfec928b8)
[08:15:26 DBG] Tree contains more branches than this component has output parameters.: component “BANG!” (5b8c41db-01d3-4c7b-8496-4cddda7adce5)
[08:15:26 DBG] Floating parameter failed to collect data: component “” (39c75b7a-707c-45c6-8f2b-261c2d52cc63)
[08:15:26 DBG] Floating parameter Txt failed to collect data: component “Txt” (f8986ba7-e3df-4719-971e-5dab16ec3626)
::1 - [2021-07-09T08:15:26.5523766+03:00] “POST /grasshopper HTTP/1.1” 500 -
Do you have the necessary plugins installed on the windows server instance of Rhino?
