# Unable to project block instances to surface
I’m not talking about this (it’s title should even be updated)! Unable to project block instances to surface - Rhino / Rhino for Windows - McNeel Forum
I mean projecting instances to a surface with some normal vector control.
Is that possible without opening the *** Grasshopper?
Do I have to start scripting again?? :frowning:
Just being able to set x, y or z for a instance selection would be nice
1 block instance added to selection.
Command: _ProjectToCPlane
Unable to project 1 object.
SetPt and BoxEdit both allow this with Block Instances.
SetPt doesn’t work on instances. Didn’t know about BoxEdit, Thanks
Hello- in V8/WIP, SetPt acts on block insertion points.
Yes, sorry, I was in the WIP when I checked. But Boxedit works in R7 too, as you’ve seen.
Thanks for the help. It solves it… in this case. Would be nice to have a project_to_surface though… is it there already?
