Hey, let’s see if we can get this cleared up for you!
From the Installation.txt file in the “Wasp 0.2.08” ZIP downloaded from Food4Rhino…
Copy the folder “Wasp” in the Grasshopper Libraries folder (File -> Special Folder -> Components)
Copy the CONTENT of the UserObjects folder into Grasshopper user objects folder (File -> Special folders -> User Objects)
Restart Rhino
A few observations from your images…
GhPython is included with Rhino 6. You should remove the file “ghpython2.gha” from the Libraries folder.
You’ve unzipped the contents of Wasp’s “UserObjects” folder into the Libraries folder, but they need to be in Grasshopper’s UserObjects folder, otherwise Grasshopper can’t load them.
The instructions explicitly say to copy the “Wasp” folder to the Libraries folder. I can see a “wasp (2).py” file in the Libraries folder. Remove this file and copy the entire “Wasp” folder again as-is.
When restarting Rhino, just close it down and run it again from the desktop shortcut or the start menu. The files in the Libraries and UserObjects folders are loaded automatically by Grasshopper when it starts.
