I am trying to blend the left surface to the one immediately to the right. The left surface seems to have a split edge, the right surface is merged. Because of the seeming split edge on the left surface I am not able to perform blend surface. When I try to merge the broken ‘S’ curve with ‘merge edge’ tool it says the edge is already merged… any thoughts. Thank You
Oh geez, I’m sorry I meant to say Match Surface. I am attempting to create G2 surface continuity between the left and right surface. When I try to select the left surface edge with the MatchSrf tool the ‘S’ shaped edge is broken into two parts.
Hi Justin - Use the ChainEdges option in MatchSrf to select more than one target edge. Make sure to ‘Match by closest point’ here and ‘Preserve isocurve direction’
