Unable to load RSTOOL plugin
i have a problem with downloading RSTOOL to my rhino 8 version SR25 (8.25.25328.11001, 24-11-2025)
educational license
the problem is inhatiliztion the plugin something about the RHP.
i had the verison 8 sr26 ‘ ive allready downgraded to the version ive mentioned above
at my friend vomputer the plugin is working.
what to do please ?
this is all the plugins i have
Installs ok on 8.27 here. What message do you get when you click the Details button in your screenshot?
This is what i get , what i can do ?
https://www.food4rhino.com/en/app/rstool
This is the link to the plugin page
Your best bet is probably to contact the plugin author via the support email link found there.
In the meantime, consider what might be pertinent differences between your system and your friend’s. For example are you both running Rhino with Netcore (the default in 8) or have you changed to Net Framework for compatibility with some other plugin? Do you have the same language settings in Windows?
I send the plugin author an email, hope it will be fixed soon , and probably not i have some plugins that he doesn’t have
