Plugin Loading Deserialization Error
I have a specialized plugin from my university (Georgia Tech) and when I type the designated command to load the plugin, I get the following error.
Command: SMUpdate
Error loading plugin. Missing Rhino3D platform
Error running command c07fce54-b4f2-4615-8906-aa17d905c498. Project deserializiation failed.
When I contacted the developer of the plugin, he said the error is with Rhino on my laptop, not the plugin itself as I could get the plugin working on an established school computer.
The problem is, I could run previous versions of this plugin on my laptop no problem so I think it is unlikely that the plugin has out-updated my PC.
Any Ideas on how to fix this?
Hi Benjamin -
You should probably start by running the Rhino SystemInfo command on both PCs and see if there are striking differences. The Rhino version, Windows OS version, and possible other plug-ins come to mind.
Other than that, I’m afraid there’s not much to go on…
If you are using Rhino 8, try switching to .NET FW
Tried it, I also noticed Netcore was on v7 so I switched to v8 since I am using Rhino 8. Neither case worked.
