I wasn’t having luck with loading third-party modules in Rhino 7. I searched through many posts until I discovered that Rhino 8 has new functionalities regarding Python. I attempted to install the packages in the site-package folder using the cmd and use the import function, but that didn’t seem to work. So, I tried using sys to provide a reference to the site-package folder, but that didn’t help either.
Could it be because the request module is not compatible with Rhino? Does anyone have a tutorial on how to install and use third-party modules for ghpython?
I’m not sure where the Rhino 8 CPython is, but it looks just like you used pip from a separate Python 3.9 installation. I think requests is installed, just in a separate Python installation than the one Rhino uses.
Do you know how to the select the python version I want to use to install the requests module? I only learned how to use pip install in the cmd. And I tried using the comand prompt in the GH component but that did not do anything.
Do you know where I can find the documentation for the solution you provided? I’d like to understand how it works so I can use it in case I encounter other issues. Additionally, is it possible to load every other packages using the same method?
