Unable to edit Layout
Hi. I am trying to jump into a layout template to move it and re align it to my technical drawing.
When double clicking, nothing happens. The is no way to edit that particular template, I can do it with all the rest. This one doesn´t respond to the double click.
Is there other way to do so?
Thank you
Hi Brunosouth,
not quite following, please run SystemInfo in your Rhino command line and post the results.
I think you will need to provide exact step to what you are doing, what are you double clicking?
I can verify the issue now. Layouts are only clickeable if there is something within it.
The question is how to move the layout canvas when is empty If I can not edit it?
Thank you
Here is an empty layout, you can move or copy via right click on the tab
