Hello whenever I create a new layout, it doesn’t let me double click so I can move the view in the layout. Does anyone know how to fix this problem? This is what appears when I create a new layout but I double click and nothing happens I’m not sure what’s going on because it used to work perfectly fine.
Hi Raul -
From your description, it sounds like you are confusing “layouts” and “details”. And from that picture, it doesn’t look like there is a detail on that layout.
If that doesn’t help, please post a 3dm file with a layout and run the Rhino SystemInfo command and copy-paste the result here.
Yes thank you that was my issue, I did have to click to add detail to be able to annotate my layout. Thank you for your help.
