Unable to create loft
Hi all,
I’m struggling to create a loft between my curves. Would anyone know how to fix this?
rhinoceros forum help 2.gh (23.6 KB)
Thanks!
Didn’t look at your file but in general the curves will only loft nicely when they have the same amount of control points.
Here’s an approach to solve the problem:
I have no idea if this is what you want, but it is a loft .
  • Set the seam
  • rebuild to same no of control points as @martinsiegrist said
    Please let us know if it helps you further. Regards, Eef
rhinoceros forum help 2EW.gh (24.4 KB)
The solids in this version are each lofted from two sections, ‘Thickness’ apart.
plane_intersect_2026Mar8a.gh (21.4 KB)
P.S. Modified slightly for R8.
plane_intersect_2026Mar8b.gh (21.0 KB)
