UI Dark/light mode is not in .INI settings
In our company we would like to have 1 .ini file that loads all the settings for everyone. This was working perfectly but with the introduction of Darkmode we have found a shortcoming.
With OptionsExport I have made a .INI file for everybody to load in.
But when colleagues have choses to set there Rhino to dark mode this happens when loading the .INI file:
(load all options)
Result:
The command bar and the text in the document properties is somewhat set with this .INI file.
I would say there are 2 option of fixing this.
  • leave the command bar and document properties black (thus remove them from the .INI as a setting)
  • Make the hole Light / Darkmode an option so this also can be set.
Hopefully this can be fixed in a future release.
Thanks,
Martijn
