Hello everyone, I’m currently trying to insert a “system configurations setting (.ini)” file into rhino, this file should change keyboard shortcuts into a premade custom shortcuts and general UI changes. The problem is: I’ve tried inserting them into display modes, rhino scripts and rhino plugins, non worked.
I’m not sure why, I’ve used this file on my other computer and it worked just fine, it seems that rhino isn’t processing the file type? It’s the only way I know how to use rhino as I’ve gotten used to its keyboard shortcuts and overlay, I’ve attached the file with this post. Thank you for your time and help.
ABD.ini (316.9 KB)
