On the document RhinoDoc you can use the property CurrentEnvironment
though which you can get the RenderEnvironment
used ForLighting
, which is the skylight environment. Once you have the skylight environment instance you can use GetParameter
with as argument the string "multiplier"
to get the skylight intensity.
