Hi all,
the tween curves from the intersection curves add for some reasons two more corner points.
Hopfully someone can help to get the right curve interpolation.
contour.3dm (80.0 KB)
contour.gh (8.4 KB)
Its is made in Rhino6 Beta
Hi all,
contour.gh (8.4 KB)
I checked your intersection lines. There are no additional controll points or something like this. Maybe @Michael_Pryor knows the answer, because it’s his addon.
But if your geometry doesn’t get much more complicated, maybe this helps you around.
tween.gh (6.0 KB)
That’s the gh native tween curves not the one from my plugin. The gh native tween has issues with polyline to polyline tweens which creates corners like that because it uses the isocurve of a ruled surface. My tween is called “Tween Two Curves” and doesn’t have that issue. You can download the plugin here: http://www.food4rhino.com/app/pufferfish
Oh sorry. Didn’t looked close enough. I’m sorry!
Thanks both of you will check your plugin pufferfish.
