Tween planar curves with planar results?
So a tween between two curves on different planes is going to result in a non-planar curve, I understand that, but if I’m working from two planar curves, is there a way I can force the resulting midway tween into a planar curve as well? I feel like Pufferfish has the tools, advanced curve tweens, and plane tweens but I’m not sure if/how they could be used in conjunction.
My sleuthing between the old and current forums didn’t turn up much but I apologize if I missed something obvious.
tween planar.gh (4.1 KB)
tween_nonplanar_2022Feb17a.gh (10.6 KB)
Genius, thank you.
I just noticed the words “with planar results?” in the thread title…
  • The white curve (below) is planar but extends outside the loft.
  • The yellow curve is an intersection of the PlFit (Plane Fit) and Loft.
tween_nonplanar_2022Feb17b.gh (19.3 KB)
Swp2 (Sweep 2) is an alternative to Loft.
Works wonderfully, you had me fooled on the first one, it looked planar in your image. Thank you again.
