Tween Curve Along Curve
Hi, can anybody explain that why tweencrv fails? (pufferfish) I thought it might be something related to seam correction but it didn’t work out.
Any help would be appreciated
Thanks
tweencrvalongcrv.3dm (30.8 KB)
tweencrvalongcrv.gh (28.7 KB)
I suppose that you mean by failing is that your curves are not flat and not on plane XY …
There is a problem with the direction of the curve so used a flip.
I used a classical Tween curves from Grasshopper
I also added a shift in curves to mimic Pufferfish
tweencrvalongcrv.gh (19.9 KB)
Hi. What is failing? It seems to be working. Were you expecting results like @laurent_delrieu? Tween curves along curve follows the curve tangents direction, not horizontality (world axis)
Also you don’t need to rebuild the curve that’s what the P input is for.
Thanks for the help that was exactly what i meant.
Yes something like that except the xyplane, I had to use the flip curve and adjust the seam for it two work. By the way thanks for the great work with the Pufferfish.
