Okay, this is a little weird so bear with me. I want to map some errors in surface flatness in a physical surface so I will make measurements and input them by hand into a panel. The values that are there are just placeholders to get the program to work. anvil-top-grid.gh (16.5 KB)
So the program creates a grid of points 2" apart. I break that up to calculate the distance between a zero point and all the rest. I take my angular error measures and find a height equivalent. All that works and I re-create the points now using the errors as Z. What I don’t understand is that when I create a surface from the points, it looks like i see more than one surface. What am I looking at? I expected to see a simple surface. Have I done something wrong or not set something correctly?
thanks,
Joe
