Trying To Revolve My Pendant Into A Fat-Rounded Object
Hi Rhino Community,
I used some of the commands to create my golden heart. The problem is I couldn’t figure out how to Revolve my heart. Can someone help me please? Here is my 3D model.
Thank you,
Damon.
HEART NECKLACE.3dm (244.8 KB)
Revolve command Rhinoceros Help
RailRevolve command Rhinoceros Help
However neither command may be what you want to use.
Suggestion - orient your object to the grid. Use Orient, Orient3Pt or Revolve. Or set the Cplane to the object.
there is no way finding out from your description what exactly you want to revolve. maybe you just want to repetitively arrange the hearts around a ring?
you might want to use BooleanUnion on the two polysurface to make that one closed object after you have ungrouped it, if that is supposed to be one solid as it appears.
this is how a revolve of your heart would look like making into into a fat rounded object which does not bring much rendering your heart shape completely useless :man_shrugging:
maybe you can make a quick sketch how that should look like
maybe you want it to look like this, which is achieved by using ArrayPolar but you would have to design the heart so that it fits a fraction of the circle to close up nicely, you can still use booleanunion but you might cut some bits off
