Hi everyone!
I’m have two grasshopper files I am using to generate a print path for a clay 3D printer. Essentially, I am using the first file to create a mesh from an image mapped surface, then using the second file to merge a tile backing + the mesh surface together to make 1 tile. After merging the two sets of curves together (which appears seemless), I then change those curves into points, and from points, into a polyline. The issue I am having is that when grasshopper builds the polyline it inserts a printline between the image mapped surface and tile backing. It seems that there is some issue in the polyline reading the order of the points correctly. Any thoughts on how I might fix it? I’ve attached the files for reference.
Trouble Shooting Tile File.3dm (11.3 MB)
April 10 - TIle Image map to Mesh.gh (3.0 MB)
Building Tile - April 9th_autosave .gh (32.6 KB)
