Hello everyone,
I am currently working on this slicer file made using grasshopper. I use it to feed a curve from Rhino that can be 3D printed.
The issue that I am trying to resolve is how to merge data from a curve that is going to be printed with a few layers (it goes from the stream filter) with data of a curve that goes around this geometry (a bounding box). They are currently connected with a merge nod and I am able to print, however first I would like the rectangle around the main geometry to be printed then the geometry. I want this rectangle curve to have a function of a skirt/brim. Now there is the opposite happening - first the closed planar curve is being printed (all layers) and then the polyline curve - as you can see on the panel.
I will attach screenshots.
I appriciate your help and you taking time to look into this!
Thank you
