Are you running cmd.exe in administrator mode? Right click on the icon then select “Run as Administrator”
Enthought does not seems to support this page anymore:
https://store.enthought.com/repo/.iron/
Does anyone know how if it is hosted somewhere else?
Hi all,
After a painful process of installling numpy. I would summarize my process as below. Hope it is helpful to everyone.
- Download all the egss here. If the link do not work, google “numpy egg enthought”
http://code.enthought.com/.iron/eggs/index.html
Download all of them to your Downloads folder
- Follow the instruction here
However, at step 6 write this:
“C:\Program Files (x86)\IronPython 2.7\ipy.exe” IronPython_numpy_scipy.py --install
It will return an “egginst” error. That’s because you do not have that module yet.
- Download ironpkg here
Copy the egginst folder to downloads
Repeat step 2
Modify settings in RhinoPython as step 3 in here
- Finally import clr, mtrand, numpy described the link above. However, please note that this only works in 32 bit. So I’m not sure if numpy works in Rhino 6 too
