I messed up the attached rhino file. The Make2D is supposed to be set to a named view. Not top view.
Here are the updated files Hatch Test 2.gh (24.4 KB) Hatch Test.3dm (369.0 KB)
With standard Grasshopper components, you can’t get the display color of sub-objects.
When you explode the polysurfaces in Rhino before referencing them in Grasshopper, you can get the display color with Object Model → Display Attributes
I would like to know the colors that have been sorted at the end of the List Item component. Not the soilds at the beggining. Because I will use their display colors to color hatches.
I can’t use the Exolode component because it doesn’t output anything that wasn’t exploded. If that makes any sense. A torus or a sphere wouldn’t come out because there’s nothing to explode.
