Looking to create a “T” letter with the top coming over the bottom of the T as show in the photo. T should be aprox 2 Milli and the raised end aprox 2.1 milli
Uploading…Either a one-rail or two-rail sweep.
- the rail curves are drawn from the top view [non-closed]
- after drawing the curve(s) flat, lift up control points to get the rise desired
- a 1-D scale will work if the rise is constant
- the profile / cross-section is a vertical rectangle, with rectangle endpoints snapped to the two profile curve endpoint (either end will work).
