I am trying to Ramp this labyrinth path… I cant seem to create a surface from the curve. I have tried to extrude the curve, I have tried sweep1 and sweep2, and I have tried offsetting the curve to either side to try and loft or create a surface from that.
@Sammie_Edery I made a loft using a whole bunch of guides. Maybe this will work for you too.
ramp from curve.gh (21.3 KB)
The width of the path has limits based on the radius of the turn. It could lead to self intersection. If you want more help it’s easier if you send the file.
I have sent a solution to this issue in pm
Basically the curve needed to be (much) cleaner in order for this to work.
