I had high hopes for the Hops component, but my experience working with them is full of problems. It’s not easy to track what is wrong each time, exaple below shows that only 1 out of 3 hops components that point to the same GH definition actually works. They should allow tree access, but sometimes they only work with lists, or don’t work at all. Even when Hops component finally works, if I close and reopen GH definition they are stuck at “solving” and I need to disable & enable Hops component for making it to work again.
I work with Rhino.Inside.Revit and I have thousands of objects to be ShrinkWrapped so I thought Hops would be perfect to solve it Asynchronously and do not lock my UI.
This doesn’t touch the topic of starting the compute.geometry and making Hops component generate themselves.
@AndyPayne
ShrinkWrap - Hops 2.gh (235.9 KB)
System Info
Rhino 8 SR6 2024-3-14 (Rhino 8, 8.6.24074.01001, Git hash:master @ def4e7ae5a5339578727a42cbd95e31d75b3faf0)
License type: Commercial, build 2024-03-14
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET Framework 4.8.9181.0
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display and OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Primary OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-15-2024
Driver Version: 31.0.15.5161
Z-Buffer depth: 24 bits
Total Video Memory: 11520 MB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.3.2.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\24.2.0.0\bella_rhino.rhp “Bella” 24.2.0.0
C:\Users\Czaja\Desktop\Rhino_7_Win_2023.0417\HDRLightStudioTexture.rhp “HDRLightStudioTexture”
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\Crayon (39629248-4fa6-47b8-83c7-745a7efea259)\1.2.0.0\Crayon\Crayon.rhp “Crayon” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\BlockEditNew\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24074.1001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24074.1001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24074.1001
C:\Program Files\Rhino 8\Plug-ins\ShrinkWrap.rhp “ShrinkWrap” 8.6.24074.1001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24074.1001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.6.24074.1001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24074.1001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.6.24074.1001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24074.1001
compute.geometry
System.AggregateException: One or more errors occurred. (Object reference not set to an instance of an object.)
—> System.NullReferenceException: Object reference not set to an instance of an object.
at Rhino.Geometry.Mesh.ShrinkWrap(IEnumerable1 meshes, ShrinkWrapParameters parameters) at CurveComponents.Component_ShrinkWrap.Compute(List1 objs, ShrinkWrapParameters parameters)
at CurveComponents.Component_ShrinkWrap.<>c__DisplayClass5_0.b__0()
at System.Threading.Tasks.Task1.InnerInvoke() at System.Threading.ExecutionContext.RunFromThreadPoolDispatchLoop(Thread threadPoolThread, ExecutionContext executionContext, ContextCallback callback, Object state) --- End of stack trace from previous location --- at System.Threading.ExecutionContext.RunFromThreadPoolDispatchLoop(Thread threadPoolThread, ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.Tasks.Task.ExecuteWithThreadLocal(Task& currentTaskSlot, Thread threadPoolThread) --- End of inner exception stack trace --- at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) at System.Threading.Tasks.Task1.GetResultCore(Boolean waitCompletionNotification)
at Grasshopper.Kernel.GH_TaskCapableComponent`1.GetSolveResults(IGH_DataAccess access, T& data)
at CurveComponents.Component_ShrinkWrap.SolveInstance(IGH_DataAccess DA)
at Grasshopper.Kernel.GH_Component.Solution_Compute_MixedAccess(GH_StructureIterator it)
CG [15:43:53 ERR] Solution exception:One or more errors occurred. (Object reference not set to an instance of an object.): component “ShrinkWrap” (f1e01c24-a8a6-4082-8a72-5d719d384c12)
Some random problem with the Shrinkwrap component inside
Hops definition is as simple as it can be…
Three Hops components pointing to the same GH definition, yet only one managed to output geometry
What are they solving? I need to re-enable them after the GH file reopen
WISH: Component placeholders instead of disappearing Hops components when compute.geometry isn’t working.
