TriRemesh Issue
Can anyone explain this?
Using the component to remesh my Mesh is okay, while it returns a null by using code.
Many thanks…
TriRemeshIssue.gh (9.7 KB)
I found it when I restart Rhino. It works again.
Since the import ghc Is not stable… The same thing happens before for using this library to compute Convex hull.
Any suggestion for using ghpythonlib ?
Hi @asdbeen53
I can’t reproduce the issue - your code works when I run it.
Which Rhino version are you on?
Hi Daniel, thanks for your reply.
Version 7 SR26
(7.26.23009.7001, 2023-01-09)
Yes when I restart my rhino it works again.
This does bother me sometimes. I have tried an iteration algorithm with triremesh before. Sometimes it will suddenly return a NULL result.
After that I will fail to run this triremesh syntax (even just for one time remesh). It will keep return Null until I restart my Rhino, then it works again.
Wonder if anyone faces the same thing before…
I suspect it is because my import of ghpythonlib (Node in Code) is not stable?
Is there a DLL. file I can call this method like your plankon dll?
Sorry I’m not sure what’s going on there with NodeInCode.
As for a dll to call the remesher directly without going via NodeInCode - not yet, but it is planned.
Thanks for your work!
not sure if this is the same issue but on my mac Triremesh does not seem to be working properly…
triremesh.gh (4.7 KB)
