Is it possible to run TriMesh in Rhino Python ScriptEditor (not Grasshopper) as a single function?
If yes, is there any example for mesh with a fix boundary features?
You might go through Rhino.NodeInCode:
@AndersDeleuran nice to hear from you:)
Is there an example for this? I never used NodeInCode
I don’t really know of much documentation, but it’s (in theory) pretty straight forward. Here’s a quick go:
250206_TriRemesh_NodeInCode_00.gh (9.0 KB)
That should work with the Rhino EditPythonScript editor as well. Not sure about the new one though ![]()
Try using the EditPythonScript editor.
Edit: This might also be a CPython 3 issue, where one isn’t allowed to import deep like that (i.e. try just importing Rhino and take it from there). It might also be another .NET incompatibility issue.
I see it working, but would be nice if cpython could handle this too:
I guess this is a rare case where ironpython aka c# is actually useful.
I use GHPython for almost everything on a daily basis, so not a rare case for me ![]()
Anywho, if you can’t get the TriRemesh function working in CPython 3 when importing just the Rhino namespace and then calling into NodeInCode from there, it’s likely a Python.NET incompatibility issue that @eirannejad might know how to resolve.
Thank you it really helps
I can still use it in script editor just shifting to python2:
#! python 2
import Rhino.NodeInCode.Components as ncc
import Rhino
def get_meshes():
go = Rhino.Input.Custom.GetObject()
go.SetCommandPrompt("Select Mesh")
go.GeometryFilter = Rhino.DocObjects.ObjectType.Mesh # Filter to curves
go.EnablePreSelect(True, True)
go.SubObjectSelect = False
go.DeselectAllBeforePostSelect = False
res = go.GetMultiple(1, 0)
if go.CommandResult() == Rhino.Commands.Result.Success:
selected_meshes = [go.Object(i).Mesh() for i in range(go.ObjectCount) if go.Object(i).Mesh()]
return selected_meshes
meshes = get_meshes()
if len(meshes)>0:
mesh = meshes[0]
T,D,C = ncc.NodeInCodeFunctions.Kangaroo2Component_TriRemesh(mesh, None, None, None, 1, 25)
print(D)
Rhino.RhinoDoc.ActiveDoc.Objects.AddMesh(T[0])
# Rhino.RhinoDoc.ActiveDoc.Objects.AddMesh(D[0])
Rhino.NodeInCode.Components is a Type under Rhino.NodeInCode namespace. In python 3 standard, it is invalid to import a type like it is a namespace. Python 2 allowed that. So:
Instead of:
write:
from Rhino.NodeInCode import Components as ncc
Here is the modified script. I also changed if len(meshes) > 0: to if meshes:
#! python 3
import Rhino
def get_meshes():
if meshes:
mesh = meshes[0]
print(D)
Thank you very much, but it does not work.
Just tried out my Rhino 8 as well. Curiously, I had to edit the GhPython/IronPython call slightly. And neither CPython call appears to work within Grasshopper:
250207_TriRemesh_NodeInCode_00.gh (8.1 KB)
System Info
Rhino 8 SR16 2025-1-28 (Rhino 8, 8.16.25028.13001, Git hash:master @ c7a440a6d57a9b9049cc7a67065ffc95676f010c)
License type: Commercial, build 2025-01-28
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: LAPTOP - Unplugged [31% battery remaining] ~23 minutes left
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 128MB, Driver date: 5-12-2024 (M-D-Y).
Primary OpenGL: NVIDIA RTX 2000 Ada Generation Laptop GPU (NVidia) Memory: 8GB, Driver date: 6-26-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.45
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-26-2023
Driver Version: 31.0.15.3645
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.16.25028.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.16.25028.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.16.25028.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.16.25028.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.16.25028.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.16.25028.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.16.25028.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.16.25028.13001
I have the same problem Rhino without grasshopper…
What is the error in Rhino? Same as the one Anders is show in in GH?
Yes the same error.
Huh!. It works like this:
ncc.NodeInCodeFunctions.TriRemesh(mesh, None, None, None, 1, 25)
Now works in legacy and python 2. But not python 3 ![]()
Okay found the problem in Python 3 and logged here:
RH-85966 Python 3 errors inspecting attribs on a DynamicObject
It works like this in Python 3. Probably safer to access the NodeInCode stuff using ghpythonlib.components handler.
#! python 3
# from Rhino.NodeInCode import Components as ncc
import ghpythonlib.components as ghcomp
import Rhino
def get_meshes():
if meshes:
mesh = meshes[0]
# T,D,C = ncc.NodeInCodeFunctions.TriRemesh(mesh, None, None, None, 1, 25)
T,D,C = ghcomp.TriRemesh(mesh, None, None, None, 1, 25)
print(D)
Rhino.RhinoDoc.ActiveDoc.Objects.AddMesh(T)
Yup, that’s what I noticed too up here. Hadn’t come across that difference before. Good to know going forward. Also, I think Daniel said that he is working on making TriRemesh exposed as a proper API at some point ![]()
Important Update:
The error thrown when using ghcomp.Kangaroo2Component_TriRemesh seems to be a regression. I have logged a ticket for this here and will discuss with @kike and @stevebaer to fix. It seems like this changed when Kangaroo was included as a Grasshoper builtin assembly.
RH-85999 Kangaroo component names has changed in NodeInCode
