TriRemesh BUG is back with a vengeance - R8 SR28 (8.28.26041)
Looks like this bug is back with a vengeance. The previous solutions no longer work at my end (connecting brep and brep mesh between extrusion and TriRemesh component. Changing the rectangle base plane location (X, Y or Z) affects the resulting mesh.
TriRemesh Bug 2026.gh (19.8 KB)
Hi Kossatz,
I opened up your file in Rhino 7, and it appears to be working the same as Rhino 8 from what I can tell. Can you provide more information about when this worked for you or what’s going on? Thanks.
Hi Japhy,
Thanks for the fast reply. I attached another test file to better explain the problem.
The main issue is the mesh topology “collapsing” that seems to be related to the extrusion component + lower thicknesses. I don´t know if this is by design or not, but should the mesh topology change when you set a different base plane location (X,Y or Z)?
Maybe Daniel Piker can throw some insights?
(attachments)
TriRemesh Bug 2026 v2.gh (21.6 KB)
Thanks for the file. I’m not sure yet what’s going on here, but this is a useful test for figuring it out.
Hi Daniel,
Thanks for joining this matter. Please let me know if you need further info or files.
@DanielPiker Bug still present in R8 SR35. Any plans to address this? Thanks in advance.
