Hello friends Why does the Trim with region component not work properly at some angles?
It’s your fault. Does tolerance make any difference?
Hi @Joseph_Oster Where did I go wrong?
I was only kidding. It’s up to you though to find a work-around, don’t hold your breath for a fix.
I see, getting the very same error here for some angles
you could create a small (closed) brep by lowering (-z) and extruding (+z) your curve and use TrimWithBrep instead, works flawlessly but calculation time are higher
