Trim voronoi cell
Hi everyone,
I want to trim voronoi cell by the green curve.
Ive tried to transform cell in curve and use
Curve/curve + shatter, but it split all cell in little parts…
The definition with internalized data
voronoi_01.gh (19.9 KB)
Thanks for any help !
Use Region Intersection
Thanks Ethan,
It works well !
New problem, I offset cells and I want to trim all intersections to get path between cells.
File with internalized Datavoronoi_01.gh (8.3 KB)
MANY THANKS !
Try this:
Use negative value for offset distance “D” input.
Hi everyone,
Thanks for your answers…
I still have a problem, I’ve offset cell negative and make a ruled surface with the original cell, but resulting surface is not perfect.
Definitionvoronoi_01.gh (7.7 KB)
Many many thanks
It requires clipper plugin.
voronoi_01_re.gh (8.4 KB)
Thanks HS_Kim
I’ll check that…
Le jeu. 7 févr. 2019 à 11:30, HS_Kim via McNeel Forum mcneel@discoursemail.com a écrit :
