Providing a file with your geometry to test makes it easier for others to help you out. In the original example you gave (which Mahdiyar kindly recreated for you) the fillet component works.
I think the control points in these corners prevent the fillet from working here. I’d call this a bug but perhaps @DavidRutten knows about a workaround. Filletcorners in plain rhino doesn’t work here either. Fillet does work when selecting the correct curves.
Nice plugin but Curved shapes are not supported, and are translated to polylines in the command.
Even after fillet It is not fully curved. I need it to be curves made from circles.
It also produces strange results at sharp corners.
Since your .3dm file is saved from rhino6 , I have traced the curve manually to show the fillet, using dicountinity and curve point
components. Here is one of the way to create fillet on curve by applying
" fillet with a parameter "component .
