Trim Damages Surface
When I perform a trim it is damaging the surface.
Attached is an example. The damage to the surface is less in this example than in my master file.
Trim - surface issue.3dm (966.4 KB)
Hi Mike- surface analysids modes use an anlysis mesh - this works better when the mesh is quite fine - otherwise you can get anomalies in the display that are just in the analysis mesh.
Ah, Thank you Pascal!
So to be certain - the deformity isn’t actually in the model?
Hi Mike- correct, the analysis mesh gets a little wonky there against the trim curve.
Thank you!
