Trim away many holes in polysurface?
I have a pattern with several hundred holes that I wish to trim away from a polysurface.
Now, the only way I know is to click on individual holes, but that’s simply not feasible. How do I click on the large surface part and tell Rhino that’s the one I want to keep instead of trim away?
A couple options:
-Boolean all the ‘holes’ together into one ‘cutter’ shape
-Use Split instead of Trim, deselect the surface you want to keep from the output, delete what’s left (probably easiest.)
Thank you!
