Trim arc line with two lines and removing trimed segment
How do i trim out ( Remove ) part B, with lines A ?
leaving the remaining Arc’s at C
Hi Glugwort,
find the intersection points between curve A and arc C,
use the resulting curve t parameter and the shatter component to split the arc.
If the curves in the centre already form a closed region, you could also use this approach.
Thanks to you all for your help.
I can advance onto my next stumbling block.
