Arc from 2 points
Good morning, I am trying to divide a circle into several segments of different lengths. I found the way to split the circle (maybe not the most effective way) but I don’t know how to get the individual arcs to edit them independently.
Thanks very much
you can use Shatter component, and connect it with your circle and the Parameters at splitting points
that way you will get a list containing all the arc into which the circle was split
