Curve intersection and trimming
Hello all,
I have to do a task that seems simple enough, but is giving me headaches. Can someone point me in the right direction?
Here goes:
I have a bunch of closed curves (Room boundaries from Revit) which are separated by Room Separators(in light blue) which should become one closed curve(as shown in Red). However I can’t seem to figure out a workflow… any ideas?
Attached is a sample file with internalized geometries.
curve_intersection_trim.gh (4.6 KB)
Exactly what I wanted! Thanks so much Riccardo!!!
Hi @Hristo ,
Looks like @maje90 gave you a good solution already but sharing this as you should be able to get away with using a single node (Region Union)
See Below:
Graph Space:
Model Space:
All the best in your workflow!
20230821_curve_intersection_trim_Response_01a.gh (5.6 KB)
Lovely! Thanks so much to both of you!
