Triangular and hexagonal grids
Hi all, I want to make a hexagonal panels as a kinetic facade on a curve surface, in such a way that half hexagonal panels would rotate on the triangular axis (I add photos for better understanding). I can do it for just one triangular panel, could you please help me?
@Mahdiyar
Mybe you must (graft + PartitionList Input) for each item to rotate (betters to people help you if send *.gh )
Thanks for replying but that doesn’t works :frowning:
As @Rh-3d-p said. Sharing your grasshopper definition can help us helping you
Delara.gh (15.5 KB)
Hi everyone,
Is there a way of doing the inverse process, convert a mesh made by hexagons and triangles (picture shown by @Mahdiyar) into a mesh made only by triangles?
Sometimes I received and input like this and I was struggiling how to do that!
Regards
Thanks a lot dear Mahdiyar, I’ve tried this one with Weaverbird’s component, just unfortunately it divides the hexagon into 6 parts, what I want is dividing the hexagon into 2 parts (one part in one triangle and the other in next triangle), is there a way to do such model?
I’m not sure if I understand what you are trying to do. I try to mimic what you were showing in this screenshot:
Delara.gh (12.1 KB)
I want this one, but in here I’ve just copied the first triangle, I could not manage it in a triangular grids
As the pattern is the same in alternating triangles, you could use Checkerboard to assign them like this:
hex_tri_quad.gh (17.0 KB)
You can use half hexagon and transformations.
hexagons_.gh (16.2 KB)
thanks a lot Daniel, it seems it works on a curved surface, just when I rotate them the whole hexagon rotates, I tried dispatch but in that case they don’t rotate on the triangle axis’s
thanks a lottt
The direction of rotation depends on the direction of the edge.
Because that definition generates the 2 types of panel by reversing the direction of the triangle, the panel opening angle for these also needs to be reversed.
The definition I posted above already takes that into account though.
Does the input mesh you are using have consistent normals?
You may just need to pass your mesh through UnifyNormals first.
hex_tri_quad2.gh (17.0 KB)
Dear Daniel could you please check my file? I can’t unify the normal vectors of panels and because of that the rotation part is not true
hexagonal panels.gh (24.8 KB)
I can’t unify mesh normals in just one direction, I want to use an attractor
