Transpose node in Grasshopper
Hi All,
I am really confused with the Transpose component in Grasshopper.
I have a list of values which I want to transpose. In Dynamo, I normally use the List.Transpose node:
In Grasshopper, I tried the same workflow using the Transpose Matrix but I am not getting the values swapped at all… Is this the equivalent node to Dynamo’s List.Transpose or do you use a different workflow to transpose values?
Please help.
I believe you are looking for the “Flip Matrix” component.
Yep, confirmed by example.
Yessss!
Oh my, thanks so much, @Michael_Pryor @diff-arch! This is indeed what I’m looking for!
and so that you know, those matrix components you were looking at are actually for transformation matrices.
