Flip Matrix with unequal branch length inserts nulls
Merging data streams with different numbers of objects, I end up getting equal numbers of objects after flipping the matrix (with some entries null):
What is the best way to avoid this? Should I be using Replace Path instead?
Since a Matrix is a “square” collection … the Flip thing does the right thing.
Anyway get the attached as a demo upon what a Transpose (i.e. Flip in GH speech) means for a Matrix. Added a C# that does the Transpose for a Tree but has an option (nulls or no nulls). Flip is also included for output comparison.
Matrix_Transpose.gh (120.1 KB)
Also try (but with nulls):
Screen Shot 041
Thank you so much for the C# script, works great!
Seems like having a no-nulls transpose would be such a useful function, too bad there is no built-in Grasshopper component for that.
You can eliminate the nulls by passing the output of the Flip Matrix component through a Clean Tree component.
-Kevin
Oh, that simple! Thanks!
