hi!
i am wondering if there is any funktion in Rhino that could change a corner point to a bezier point(or a curve point?) without deleting it and adding a new one?
Thanks in advance!
hi!
Thanks in advance!
check if
_CurveThroughPolyline
does the job you need:
Degree = 2
Curve Type = ControlPoint
Delete = No
if not maybe provide a example / screenshot
Hello- not exactly - in the sense that illustration programs do this - Rhino curves are Nurbs curves. You can InsertKink' at any location to make a 'corner' and
RemoveKnot(three times for a degree three curve) at that location to remove the kink. You can also draw using
HandleCurve` to get something like a Bezier-drawing experince but I’d say it is really better to get used to using Nurbs curves, they are much more powerful in the end.
