Transferring Rhino to blender
@nathanletwory I tried the blender importer you wrote, but I don’t get good result with it as the normals of the meshes are not being transferred properly. If I export as OBJ, it gives close to perfect results. So I wonder if you can make the importer for Rhino files behave the same as the OBJ version, with the added benefit of importing the size correctly :slight_smile:
example Rhino objects (turned on mesh display to see the differences, custom meshes):
imported in blender:
imported as OBJ:
rhino_import_test.3dm (326.6 KB)
Thanks for the report. I’ll check this soon.
Looks like the OBJ importer in Blender automatically applies a Merge by Distance operator. For now you can do that manually after import.
The issue for that is remove doubles as automated post-process step · Issue #92 · jesterKing/import_3dm · GitHub . I’ll add this topic to the issue as well.
