Transferring all Rhino settings to new computer
I have just been supplied with a new work PC and would like to transfer all of my Rhino profiles, toolbars, graphics settings etc over to the new PC.
Is there a quick and easy way to do this ?
Mike.
Hi Mike,
type _ToolBar then from the Files list, locate your desired toolbars and save a *.rui file using File > SaveAs in the desired export location. You can also copy complete workspace but close Rhino before, they are usually located here:
C:\Users\UserName\AppData\Roaming\McNeel\Rhinoceros\7.0\UI
To transfer options, settings, aliases etc. use _OptionsExport and _OptionsImport commands
In case you have modified display modes, run _DisplayAttrsMgr then highlight one display mode and click on Export button. You can Import within the same dialog on your new PC.
_
c.
Hi Clement,
Fantastic,
Thank you !
Regards,
Mike.
