Hi all, I’m looking for a way of transfering window appearance settings to the customer’s machine. I searched through existing topics as well as Transferring Personalized Settings [McNeel Wiki] and Using Schemes to Start Rhino [McNeel Wiki] made by @Helvetosaur but it seems that approach for Rhino 8 isn’t published yet.
What I want to achieve is a window with no title, menu, status and selection bars, no toolbars other than ones that come from my plugin. There should be an option for showing/hiding bars with specific keyboard shortcuts.
My current workflow was: 1.export .ini with _OptionsExport, 2. edit it, to not have bars, 3. import it to rhino using _OptionsImport, 4. close all not needed toolbars 5. close rhino 6. store whole settings folder from AppData to replace the one on customer’s machine.
And my questions are:
- Is there any easier way for that? While I’m able to import .ini file easily, it doesn’t affect toolbars and there is no command form for importing window layout from a file.
- How can I control the size of certain toolbars while the rhino is starting? To i.e. always launch the command line with a certain width.
- Is it possible to add a trigger for showing/hiding all not needed bars with a shortcut?
Thanks,
TP
