Toolbar sync PC to Laptop
Hi
I mainly use Rhino on my PC but occassionally go onsite with a laptop and use Rhino. The issue I have is I have customised by toolbar layout on my PC and I would like to have the same on my laptop however I cannot see the RUI file on my laptop that was saved on the PC.
Basically is there a simple method of sharing toolbar/workspace/keyboard shortcuts between computers.
Cheers
ib
Hi Ian -
If you have a custom layout, you can save that from the window layouts panel and export that to a . rhw tile that you can import on a different computer.
-wim.
HI Wim
thanks for helping on this. For some reason I cannot make the function work. I need to spend a bit more time to investigate why.
Hi @wim
I finally got it to work and the issue related to a third party product (MS Onedrive was not sync between accounts). I saved the file on a usb and transferred to my laptop and the process worked. Thank you
