Hello, I imported a toolbar into rhino 5 and saved it,but the next time I use Rhino the imported toolbar has disappeared. Any ideas as to what is going on?
Thanks in advance, George
Hello - if you import a toolbar into your current RUI (toolbar file) and that RUI is called ‘Default.rui’ it can be overwritten by the actual default toolbar file- do a SaveAs to some other name, import your toolbar and then Save the file. Any better?
I have it saved as Georges .rui. Is that ok?
Hello - that is fine with me if it works for you… but did it help?
