The latest Rhino 8.3 release candidate (Dec 19) contains a test command called TestTb8. This command is in place while we adjust the user interface involved with creating and customizing toolbars.
Once you run TestTb8, the following changes take effect. The Toolbars and Containers sections of the Options dialog have been removed and replaced with a Toolbars and Size and Style sections.
Many things should feel the same as Rhino 7 with the Toolbars section, but there are also a number of subtle changes worth mentioning
Multi-select in the toolbar/group list is supported. This can be used to create a new group.
When selecting a toolbar all of the buttons for that toolbar are presented at the bottom of the page. These buttons can be clicked on to select them for editing or deletion.
There is still a lot of fine tuning that needs to be done as well as already reported bugs that need to be fixed. Please be patient while we make these adjustments.
All feedback is welcome. @Helvetosaur my hope is that this will get us closer to a usable system instead of forcing you to adjust to a “different way”.
