I have a problem with Rhino4. The default toolbar has desappeared, and does not come back when I make a reset. It looks like there is nothing left of it in the window below. Can you help make it “reappear” ?!
Thanks a lot
Véronique
Thanks a lot
Véronique
Hi Veronique
Did you try the _ToolbarReset command?
(not sure what the french command is called)
-Willem
Yes I did. The image I enclosed is what I get after the ToolbarRest command.
You may try the following procedure (was written for Rhino5, just adapt the paths)
Rhino 4 5
molette souris non fonctionnelle pour zoom, barres d’outils
Hi Veronique- there should be a
“C:\ProgramData\McNeel\Rhinoceros\4.0\default_backup.tb”
toolbar. Use the File > Open menu in the ‘Barre d’Outils’ dialog to see if it is there- if so, Open it, Close ‘default.tb’ and SaveAs 'default_backup.tb ’ as ‘default.tb’ .
Does that work?
Hello Alan, thank you for your suggestions. Here below what I see on my screen. Can I copy Default_backup in default ?
I am almost there, as I could reestablish the toobar on my screen. I still hav a position problem (second picture) : they cover the names of the Windows.
Véronique
Bonjour Pascal,
Je suis sous Windows 8. Où dois-je taper ce “regedit” ?
Cordialement
Véronique
Bonjour Veronique,
Tu as donc bien le fichier ‘default_backup.tb’.
Dans Rhino, il te manque toujours la barre d’outils principale.
Suis la suggestion de Pascal afin de recharger les barres d’outils par defaut.
Démarre dans Rhino,
menu ‘Outils’ …
