Hi Pascal and All, maybe asked before but, if a selected object is highlighted and you want to toggle through the views, will that object be centered in each view or possibly zoomed in with any view toggled.
Not sure if it is a good practicebut, I work a lot in perspective view. I pick an object and then go to top view and have you refind and pick it once more . Any help would be great, thsnks Mark
Phones are not good typewriters
My opinion would be , it could be a nice feature. Unless I’m missing it already
Hi Mark, Try this… select the object you care about and then use the ZSA command. This will zoom to the selection in all viewports. If your viewport is maximized already, use ctrl+tab to cycle through the other views.
Zsa worked wonderful thanks Brian ----Mark
